12-29-2024 11:04 PM
Looking at this plan. Sometimes I use all my data and would be nice to have unlimited data even though it is slowed down.
Currently on 34.00 for 60 gigs and it is throttled after 60 is used up.
12-30-2024 07:14 AM
@atticuss66 I think @Handy1 has the right idea. There is no way you are using the equivalent of that extra 15GB of data at a reduced/throttled speed.
12-29-2024 11:07 PM - edited 12-29-2024 11:12 PM
@atticuss66 No it will just stop working once the 75GB is used up until your next renwal day or you buy data add on to get you through till next renewal day
the 5G non roaming plans ( Canada wide) do have unlimited throttled day but none of the 5G roaming plans have unlimited throttled data
adding @atticuss66 i was in the 60GB $34 plan and switched to the 75GB $35 roaming plan the extra 15GB is worth more and makes up for the throttled data I could ever use
