bouns doesn't add to my account
shahinpour_m
I am new in public mobile and my plan is 4.5 GB data + 3 Gb data for 6 first month.But it doesn't  add to my acount.   What should  I  do?
8 REPLIES 8
@shahinpour_m wrote:
That's correct, it was 2 GB and I activated  online on Oct. 22 but it did not  mention  about using  the  promotion code. I did not use it. what should I do? Thanks
It said that you must use the code BONUSDATA. All you can do is ask moderator for an exception but they don't have to apply it because the terms weren't followed. You'll have to hope the moderator says yes.
shahinpour_m
@shahinpour_m
Was this the promotion that you signed up? The promo ended on October 26 and the 2 GB should have been in your account within 7 business days.
https://productioncommunity.publicmobile.ca/t5/Announcements/SALE-Get-a-bonus-2GB-of-data-when-you-a...
Did you use the promo code on activation?  Also, did you do at home, online activation.  If you signed up in store, you would not have qualified for this promotion.
If you meet all the criteria, contact the moderator.
shahinpour_m
This promotion  was in 20 days ago.
Thanks
ChuckYeah
@shahinpour_m I just re-read you thread and the current promo is a "one-time" 3GB data bonus, not for 6 months. If your reading this wrong, you should be aware of that as well.
geopublic
@shahinpour_m  Don't worry be patient and it will show up provided you met all the conditions. If it doesn't show up after 10 days you need to submit a ticket to Public so that they can investigate and apply it manually.
ChuckYeah
After 10 days, you can create a support ticket.
Creating a support ticket:
Explain your issue to SIMON, seen below:
SIMON
Use as few words as possible to allow the BOT to understand. Answer his questions until you get here:
Create a support ticket
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
ChuckYeah
The promo says it may take up to 10 days to appear. If it hasnt been 10 days, just sit tight.
