Wrong number imported
11-09-2019 09:23 PM - edited 01-05-2022 07:55 AM
Need help. I have multiple accounts with Public and because they had to be under different logins I made a mistake. Account A (Public) should be live but I imported account B (from a different provider) to account A, replacing phone#. I also have account C (Public) which was meant to have phn# from B. Is there any way to reverse this without losing account A phn#? Thanks
Joining Public
11-09-2019 09:33 PM - edited 11-09-2019 09:35 PM
@mimmo wrote:only mods can help you in this situation. when contacting them be as specific as possible with the details and waht you want to happen . include the account numbers and pin of all the affected account.
@Nadinka ensure that mods know you need to keep both numbers that line A had. Skip all that line B and C stuff. It's not needed and will make it harder to understand. Concentrate on getting all numbers back, not which account they are in because they won't swap them.
11-09-2019 09:30 PM
11-09-2019 09:27 PM
Only the moderators can help. Click on the question mark on the right lower corner to start the ticketing process to contact moderator. Type: contact moderator and follow the prompts.
Another possibility is trying to call the Telus porting team. Several PM customers have had success with calling the Telus team.
11-09-2019 09:27 PM - edited 11-09-2019 09:28 PM
@NadinkaIt would depends on the cirumstances and timing. You can try to contact the moderator to assist.
If your Account A number is not from Public Mobile, it would be released back to to the provider the number is orginally from or somewhere in a "purgatory". Also do note, Public Mobile doesn't allow transfers of numbers between Public Mobile accounts.
You would have a better time retrieving number A if it is from Telus or its subsidaries
11-09-2019 09:26 PM
@Nadinka wrote:Need help. I have multiple accounts with Public and because they had to be under different logins I made a mistake. Account A (Public) should be live but I imported account B (from a different provider) to account A, replacing phone#. I also have account C (Public) which was meant to have phn# from B. Is there any way to reverse this without losing account A phn#? Thanks
Mods won't move numbers between one Public account to another. You will need to open a new Public account and hope mods can get that number back.
11-09-2019 09:26 PM
You cannot port a number within PM. So best to get in touch with a moderator to see what they can do? Otherwise you'll have to port numbers out and that will make it a bigger mess.
Creating a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand. Answer his questions until you get here:
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
