04-22-2022
06:39 PM
04-24-2022
09:24 AM
computergeek541
I ordered the wrong phone today. Is it possible to either cancel the transaction or adjust it so I get the correct phone?
Phones
05-02-2022 04:06 PM
Luddite: I haven't tried it yet but if a password change changes the other then they're one account. If they can have independent passwords then indeed 4. Anybody remember if this place remembers old passwords and stops you from using it?
05-02-2022 03:59 PM
@dust2dust "There are three "accounts " used here. 1. the shop account, 2. the service account, 3. the community account."
Make that 4 accounts - self serve and rewards/points are now separate logins, though with same username & password. 😵💫
04-24-2022 10:57 AM
I received your message that the order has successfully been cancelled. Thank you very much for your help! I appreciate it.
04-24-2022 09:12 AM
I hope your day is excellent!
I'm just following up on your case to check if you still need assistance from our end, also I would like to mention that the system will close the ticket 24 hours after its creation of it.
We will be waiting for your response.
Thank you for your time.
Kind Regards,
Francis
Customer Support Agent.
04-22-2022 07:12 PM
Ah, that makes more sense! Thank you for the clarification.
04-22-2022 07:10 PM
Without a sim you can't have a service account. You obviously have the other two accounts (1 and 3). They are each in their own world. The community account and service account are related by email address if you want to earn community points. But not the login.
04-22-2022 07:09 PM
Thank you! I sent a message. And also sent a ticket: it went through this time. Fingers crossed
04-22-2022 07:04 PM
Yeah a private message would suffice. If you just made it, you can probably cancel it to order the one you want as it takes some time to be processed, but time is of the essence.
04-22-2022 07:01 PM
@Fwecxsteen for your situation, just direct message PM Support here:
04-22-2022 07:00 PM
@Fwecxsteen- Try this link to send a message:
04-22-2022 06:57 PM
In fact, I opened an account (without using a phone number), received a confirmation email, clicked on the link and was directed to a page saying my registration was confirmed, but I still can't log in with these credentials and therefore can't open a ticket.
04-22-2022 06:53 PM
Yes, thank you, I tried, but I have to open an account, and I can't seem to be able to open an account. I do not have a phone number currently.
04-22-2022 06:50 PM
@Fwecxsteen - You will need to open a ticket (use the Get help shortcut). Since it is 'fresh' they might be able to cancel the order.
