05-02-2022 11:44 AM
Can I post my referral code on this forum so that other customers can get the $10 credit?
05-02-2022 01:55 PM
@hTideGnow wrote:HI @JL9 technically it is to give out to friends only. PM has the right to forfeit the rewards if the code is posted publicly.
Agree. Some company asks for the name of the referrer.
It is hard to support the referee if you don't know them. They may stay with PM until they encounter a problem and leave PM after going in circle by SIMon without creating a support ticket.
05-02-2022 01:22 PM
05-02-2022 12:28 PM
You can go to various places if you want to get your referral code out there. For instance Reddit's Public Mobile Group has an option to put your code in for ppl to request, by the luck of the draw since there are dozens of codes in there. Very few and far between but you may get lucky one day lol..and a buck a month is a buck a month.
05-02-2022 11:51 AM
Or a point per cycle depending on what system you're on.
05-02-2022 11:51 AM
@starman85 wrote:Ok. Thank you for the quick reply.
Do you know if there is an expiry on referral code?
The refer-a-friend code does not expire. It is only for your account. My code does not change since I activated my account over 3 years ago.
Welcome to PM and enjoy your saving.
05-02-2022 11:50 AM
HI @starman85 the code itself has no expiry date. it will work as long as you are with PM
The receiver , new activation will get a one time $10
For you, who giving out the code, you will get $1 /cycle as long as the friend you referred have active account with PM.
05-02-2022 11:47 AM - edited 05-02-2022 11:48 AM
05-02-2022 11:46 AM
No. Self-promotion is not allowed.
