08-18-2022 08:53 AM
08-18-2022 10:33 AM
@spaultimate When did you buy the voucher?
If over 24 hours and still does not work, open ticket with CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing: cannot process payment
Then select "Payment Voucher"
then click "contact Us"
finally click "Click here to submit a ticket"
08-18-2022 10:10 AM
Without more info about your voucher purchase the best guess is it is not from a retailer that sells vouchers that are immediately valid. You can find out more about vouchers and the different retailers in this post.....
08-18-2022 09:07 AM
@spaultimate Where you got the voucher from?
Voucher from some stores could take up to 24 hours to become Active. If it has not been 24 hours yet, please wait
If it has been over 24 hours, you can try to load your voucher using *611 or Self-Serve My Account.
08-18-2022 09:04 AM
@spaultimate hi it sometimes takes up to 24 hours to activate , you can submit it at *611 or in your self serve,also you can contact a cs agent to help input it
to contact a customer service agent
you will need to open a ticket, to speak to a customer service agent Click here you can check for a response in your community envelope top right corner next to your avatar, or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
