a month ago
Been a customer for years and now my service isnt working when I paid with a voucher. need someone to activate my account
a month ago
@ryancardoso wrote:Ive restarted many times, the problem is on their website. It still says unpaid but they removed my voucher balance
If that's the case, you should click on the orange bubble on bottom right side of page to start process of Customer Support intervention. Give them your cell #, account #, name on account and PM pin #...plus let 'em know what the problem is. They should be able to get your going again.
a month ago
a month ago
it's a long-shot but worth a try...shut down cell and remove sim. After a moment, replace sim and restart. Hopefully you'll get positive result.
a month ago
Please read my post before commenting, but I have restarted my phone multiple times and different durations
a month ago
hi @ryancardoso
you need to reboot your phone for the service to kick in
if that still does not work, login My Account, go to Payment history and check. You should see a line about the voucher being loaded in to your account , there should be another line showing the money being used for renewal
a month ago
Payment voucher was added via browser of $35, Purchased $25 plan confirmed $10 remains in the account. Cart is displaying a $30 plan as a renew option
a month ago
how you load the voucher onto your account? use *611? or on browser or via app?
if you can *611 from your phone (or 1-855-4PUBLIC from another phone to check), does it tell you the voucher successfully loaded?
or if you want PM to help, message them (i assume you cannot login My Account and can't open via Chatbot):
