03-15-2024 11:02 AM
I have the same Sim card in my phone, I also have the eSIM activated.
I’ve responded to the texts from Rogers and the transfer seems to have been done. But ever since I did this yesterday I can now no longer make any phone calls.
03-15-2024 01:14 PM
I found it took about 48 hrs for the port to complete and everything to work.
At first it was sending out texts and phone calls, and then it was receiving calls and texts. Eventually, everything started working as it should. Give it some time unless you're past the 48 hr mark
03-15-2024 11:09 AM
If you old Rogers SIM is in your phone.Remove it and check to see if the eSIM setting is connected to PMand reboot your phone by powering off then back on.
03-15-2024 11:09 AM
@HeatherNL if you have a PM eSIM, remove the Rogers sim and reboot. Then check if PM esim is enabled (and on iPhone, enable Turn on this Line and change the label to Primary)
03-15-2024 11:06 AM
Which company is the SIM card? eSIM? Need to have PM SIM or eSIM the active SIM. Remove or inactivate any Rogers SIM or eSIM.
Are you able to receive calls or texts? What about data?
Might want to reboot phone. Network reset of phone (note this will erase any saved Wifi passwords).
