eversafe: opting out
Sheilaphone
how can I opt out of eversafe?
Phil_Adelphus
@Sheilaphone   Have you tried the "Trusted Device" option (under the code boxes)?  It doesn't work for everyone, perhaps because of clearance of cookies etc. on exiting the browser, but it does work for others including myself so may be worth a try.  You still have to log in with Trusted Device but it doesn't send a text with the code most of the time, you just get straight in.
@Sheilaphone
Eversafe ID is a security login for PM to prevent any unauthorized access to your account from SIM Swapping.
@Sheilaphone EverSafe is then login system PM uses for Community and My Account login
May I known what the issues you are encountering??
hairbag1
@Sheilaphone
you can't...that's part of PM's latest safety features. Are you having trouble logging in or ??
TheSterlinger
You can not opt out if Eversafe. That is the system Public Mobile uses for signing in.
