porting number problem
Jasminekimberly
Hi there. I port in my Koodo number to public mobile 7 hours ago and I still cannot make outgoing and receive incoming calls. I don't have data too. My Koodo number is already cancelled. I check my Iphone setting and it says I am on Public mobile. When I tried to make outgoing call, it says I have paid but I did when I subscribed this morning. Pls. help. Thank you
Nitethawk
This is what I did to help my sis transfer from Virgin.
1. I imagine your first SIM card is a physical SIM card, and you transferred to a eSIM?? Easiest fix is to remove your Koodo sim from the phone. And reboot your phone.
2. if you don’t want to bother with removing the sim, then make sure both your cellular data and default phone line are changed to use your new eSIm. (In my example, I’m still using both lines)
hi @Jasminekimberly
your sim or account was not setup properly on the system, just ask support to help.  you can submit by direct message:
Chalupa_Batman
Have you rebooted your phone? Also, try to reset your network settings even though Koodo is on the Telus network. If you still have issues, reach out to a CS Agent.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
