Unable to activate eSIM
satelitas
I ported my number from Koodo to PM. iPhone had an eSIM (Koodo). On Koodo account I see my number is gone, means transfered, so no problem here. But probably I did a misstake by deleting eSIM with Koodo information. When I trying to add eSIM from introduction PM email QR code, I get message "Unable to Activate eSIM". What to do now
satelitas
I solved problem by getting a new SIM from Amazon. Agent transferred my original phone number on the new SIM. Not sure if I still can convert physical SIM to eSIM once the latter was deleted.
satelitas
When you say "disable" do you mean - delete?
satelitas
Problem is I deleted (!) Koodo eSIM
hi @satelitas
disable the Koodo's eSIM
then reboot phone and Reset network settings
  Go to the sim manager page or settings -> cellular and make sure the PM is enabled and set as Primary (or Turn in this line is toggled on if iPhone)
you should be good then. Test both inbound and outbound calls
Phil_Adelphus
@satelitas   You can open a ticket with customer service at the chat icon bottom right of this page, but if that doesn't work an alternative is to send a private message to support using this link
An agent will reply at the envelope icon top right of t his page, or tap your avatar to access Messages if you don't see an envelope.  Their hours are 9 a.m. to 10 p.m. eastern time.
