CAN-USA-MEX Subscription
fscool
I am on the $35 CAN-USA-MEX subscription plan.  This plan does not include Roaming, right?  Meaning if I go to the USA I still need to purchase a Roaming add-on?
7 REPLIES 7
DennyCrane
Make sure you turn data roaming on in your device settings. You're still roaming when you're in the US and Mexico, but it's included "free" of charge.
LindaThai
Please note you might get a notification when you cross the border for buying roaming bundles (automated message). You can ignore them as you have a plan that includes roaming in US-CAN-MEX. So don't freak out. 🙂
@fscool wrote:
Thank you for all of your replies.  Thanks for the additional info about volte and the whitelist too!
Click this link and scroll down to see if your cell is on the list...
https://www.publicmobile.ca/en/bc/get-help/articles/volte
fscool
hairbag1
That plan you have will allow you to use your PM service in all 3 countries...just as if you were at home. No other add-ons needed. If going to US, make sure you have a volte enabled cellphone that's on the PM whitelist of volte enabled phones...not all cellphone are on that list. Without volte, your talk features won't work in USA.
@fscool
Yes it will work in all 3 countries without the need of roamng. It is all good included.
Chalupa_Batman
Hello @fscool
No. This includes roaming in both the US and Mexico. No add ons needed.
