12-01-2024 01:29 PM
Hi all, just redeemed 15 points for a $15 discount towards next month's bill however the Public Mobile balance does not add up and is lower than it should be. Has this been seen before?
Started with 29.2 minus 15 = 14.2 (however PM points balance show 11.9)
What am I missing?
Thanks,
12-01-2024 10:42 PM - edited 12-01-2024 10:42 PM
In my own opinion, no system is perfect.🙂
12-01-2024 02:10 PM
Thanks for the positive feedback. Just goes to show that one has to double check and not rely on the accuracy of the system.
12-01-2024 01:56 PM - edited 12-01-2024 10:41 PM
I can relate to this. I also had an issue with my points balance, and it was rectified after I reached out to customer support. I'm sure yours will be looked at as you reach out to them.
12-01-2024 01:40 PM
Thanks for the link. Will submit a request.
12-01-2024 01:39 PM
I wonder but still does not add up
12-01-2024 01:36 PM - edited 12-01-2024 01:37 PM
12-01-2024 01:31 PM
wonder if that includes taxes when you redeem points.
12-01-2024 01:31 PM
@CY63 Ask support to investigate for you
