02-16-2023 03:47 PM
when i signed up it was for out going calls only , now im being charged for incoming and out going calls ?
02-16-2023 10:55 PM
@hTideGnow- The thousands of other minutes aren't enough to test 1 or 2 minutes with? 🙂
02-16-2023 10:21 PM
Lol....practice? I've just noted over hundreds of calls if I tick over to 53 seconds I get "charged" 2 minutes instead of 1 minute. If I hang up at 52 seconds usage records 1 minute. If I call a pm number and hang up at (not after) the 5th ring it still connects to voicemail and records 6-7 seconds of usage. If I'm too slow fo react and I hang up just as the voicemail connects it records 8 seconds of usage. If I hang up after 4 rings but before 5 rings then no call is recorded. That's my phone(s) experience with calling other pm customers. While I do call non-pm customers it hasn't been enough for me to make note of and recognize a definitive pattern. If you call a landline with no answering machine or voicemail set up and you let it ring 20 times before someone answers then they hang up your usage might end up being 2 or 3 minutes if the ring time exceeds 1 minute or more?
02-16-2023 09:33 PM
What are the charges? This doesn’t seem right. Can you post a screenshot of your incoming and outgoing charges?
02-16-2023 09:20 PM
02-16-2023 08:40 PM - edited 02-16-2023 08:50 PM
@hTideGnow- Experimentation? Try it out. See what happens. Regardless of whether you're on the $15 plan, you can look at the total time in your usage details.
Adding - I just tried it. Looked at my minutes. Dialed. Little spinner icon. It jumped up adding 3 minutes. Didn't let the other end answer. Little spinner icon. Went back to the initial number. Nothing in the usage details. Dialed. Same 3 minutes. The other end went to voicemail (dialed my other sim on the phone). Little spinner icon. Phone says 4 seconds. Little spinner icon. 1 minute. Usage details shows 39 seconds.
02-16-2023 08:32 PM
Hi @darlicious
how you know all this??
For the 7 seconds ring. if it is really 7 seconds the ring and actual talk time of 5:53, does it show 5:53 our the usage history? or show 6:00?
and what if the ring just 2 seconds, and the talk time is 5:53, does it count as 5:55 and hence 6 mins? or PM will add 7 seconds anyway?
and in some case, if they ring is longer than 7 seconds , like 10 seconds, does that mean a call of 5:50 will be counted as 7 minutes already?
02-16-2023 05:46 PM
You're missing something, @raider
Check your SELF-SERVE usage history screens against your device calling history to ensure you're capturing all the outgoing calls.
The counter is unlikely incorrect for the cycle (which runs 30-day consecutive cycles, not calendar months)
02-16-2023 05:27 PM - edited 02-16-2023 05:36 PM
For the $15 plan please note the following......
02-16-2023 04:33 PM
The $15 plan only charge for outgoing calls rounded up to the next minute.
You may have answered your voicemail but when you answer the messages…you are making an out call to your voicemail box.
02-16-2023 04:10 PM
@raider one more thing, PM is on a 30 days cycle. So, cycle start day will chsnge. Did you start counting from the.corrext cycle start day?
02-16-2023 04:01 PM
yes i did
02-16-2023 03:59 PM
@esjliv did you round up the usage minutes?? a 2 seconds call and a 59 seconds calls both counted as 1 full minute
02-16-2023 03:57 PM - edited 02-16-2023 03:59 PM
@raider wrote:just checked my account only have 7 mis left from a 100 , checked all outgoing call only used maybe 60 , so something is not right .
@raider - note that all calls are rounded up to the nearest minute. So, as soon as you hear calling on the line when you are making a call that is when the 'charge' begins (edit, but the recipient needs to answer so the call is connected for it to count) , if you hang up at 10, 35 or 47 seconds (for example) than all these would round up to 1 minute.
02-16-2023 03:57 PM
Only use the usage details as a way to see all the activity in and out of your services. They do not mean you're being "charged" anything.
A test to verify would be to log in to the account and click on the little spinner refresh icon lower down under the plan information that shows your base plan features.
Then from another phone or voip app, call your number. Answer it and waste a few moments. Maybe even a full minute or so. Hang up. Wait another number of moments.
Then click that refresh icon again and see if the minute counter changed. It shouldn't.
(not the browser refresh up top...the lower down one)
02-16-2023 03:56 PM
@raider - adding to @computergeek541 post, if you are seeing a phone number ending in 4001 or one of these voicemail access number:
then this is simply you accessing your voicemail or someone calling into your voicemail.
Calling your voicemail from your device DOES consume your 100 outgoing minutes. But there is a workaround...call you number from another device and this DOES NOT consume your 100 outgoing minutes from your plan.
02-16-2023 03:55 PM
02-16-2023 03:51 PM - edited 02-16-2023 03:52 PM
@raider $15 plan only has 100 out going mins , but PM is pre paid so you won’t be charged any more then you plan amount …. If you haven’t got the minutes there’s no mins to charge you for
02-16-2023 03:50 PM
@raider wrote:when i signed up it was for out going calls only , now im being charged for incoming and out going calls ?
There are no extra charges on any plans. As for the currently offered $15 plan, incoming calls are unlimited and don't count towards using up your 100 outgoing minutes. If you're looking at your Self Serve account usage details, there will be some outgoing calls listed to a voicemail deposit number when callers real your voice message box, but those do not use up any part of your 100 minutes.
