5 hours ago
Does the amount show under payments as a reduction right away? Just want to make sure it goes through as points were already taken.
4 hours ago
@BKNS27 ok, thank you that's what I thought. It would be nice if PM had different redemption levels, as per another post I made a few weeks back.
4 hours ago
Yes 2x$15 3x$15 etc.
4 hours ago
@Dolphin12, must be what @BKNS27 means as I don't see a $30 option either, 2 x $15 would accomplish the same
4 hours ago
@BKNS27 I didn't see a $30 option. Do you mean cash in the $15 x 2?
4 hours ago
You will manually redeem 15 points for $15 credit towards your next bill from your account.
You can also wait until you have 30 points for $30 credit.
4 hours ago
@eddieO I used it towards my bill payment. I will wait until next week and check the payment tab. Thank you it's my first time doing this.
5 hours ago
@Dolphin12 did you use it towards a $15 bill credit or towards an add-on? If towards a credit it should show up in the PM app under the Payment tab, a spot that shows "Available Funds" which will go towards your next bill payment. I believe it can take a day or 2 for your account to be updated with the information
5 hours ago
You need to have minimum of 16 points to redeem it for $15, once you redeem, it will show as $15 under available funds, will be used in your next renewal
