Upgraded with promotion, but my old plan is fully charged?
ilpalazo
Hi there,
I had access to a promotion and decided to upgrade immediately, but was surprised that there is no prorated amount for my existing monthly plan or any kind of refund? I basically paid twice in a row for the same core service. Every other service provider prorates the amount you have to pay in this circumstance.
What gives?
walker1
@ilpalazo
Only postpaid phone providers offer prorating and partial refunds.
Since Public Mobile is prepaid only, there's no prorating or refunds here.
When switching plans, it's always best to schedule your switch on your renewal date, so you don't lose anything or pay twice.
HI @ilpalazo   this is normal.  PM is prepaid and no prorated or partial refund for unused part of the plan
Every other providers you think is different as they are prepaid provider
But what you meant by you paid twice in a row
if your original plan renewal  was today, and then you make another plan change right after, there is a chance PM agent can help.  But if your current plan was already many days in and you made the plan change, then they won't do anything
You can try to open ticket with CS agent and ask for help in your particular case:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Outdoorsman
@ilpalazo hi not all pro rate their plans only post paid as a rule ,here you are on a prepaid plan therfore there is no prorating sorry ,it is best to do your homework before changing plans
Yummy
That is correct; you paid twice since you already paid for existing plan AND you decided to change plan NOW. You were immediately charged for new plan.
PM does not refund difference when upgrading/downgrading plans. No prorates at PM.
