Update Payment Info
05-18-2022 11:15 PM
Hi I would like to update my credit card info for auto pay, can you tell me how r can set this up?
Payment
05-18-2022 11:31 PM
Once you do this manually as laid out it should be good to go for autopay going forward, if you can avoid autopay failures, etc.fingers crossed
05-18-2022 11:20 PM
I just click on one time payment and in the middle of the payment page you can click on manage my card. Then I follow this procedure....
Follow this method when making a manual payment/adding a card to the account....only use the emboldened portion of the instructions if the payment card is already on file.
- Reboot your device.
- Clear your browser, use secret/incognito mode in firefox, chrome or safari.
- Choose replace card rather than remove card.
- Copy your address from your billing statement.
- Add your apt/unit/suite # to the street address. ie. 101-123 1ST AVE W, CITY, PROV.
- Do not put a space in the postal code. X0X0X0 not X0X 0X0.
- USE ALL CAPS if necessary.
- Do not use autofill. Type everything manually.
Once you successfully update your card do not attempt your payment immediately. Log out/in then go to make a payment to pay for your renewal. Otherwise if you were not suspended I would recommend a $1 test payment. Follow my further instructions for a successful payment to unsuspend your account.
Do not try more than two attempts at adding a card or payments ( successful or not) or you will continue to get this message. Wait at least 1 hour to try a third time another hour for your 5th try....and so on....and do not make more than 4 unsuccessful tries with the same card in a 24 hour period or you will trigger a fraud alert lock out requiring assistance from customer support.
Go to make a payment. Choose the "other amount" option and add $1 more than the amount owing and submit the payment. If that is successful go back to your overview page and if it does not say active click on the reactivate button. If that works log out and reboot. If that does not work and your payment is in your balance rather than showing $1 then go to the usage or plans page. Click on lost/stolen and suspend your service. Log out/in. Resume your service. Your balance should now be $1. Log out and reboot.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-18-2022 11:19 PM
It is advisable when using self service to use chrome or edge browser and clear your cache first and go incognito.
05-18-2022 11:17 PM
@Shamagandhi You will need to login to My Account. go to Payment page, click Mange my card, then Replace this credit card.
https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/
05-18-2022 11:17 PM
Log in to your account / Payment/ Scroll down to Manage my Card.
