Locked out
03-17-2025 06:31 PM
I have been locked out of my account. My phone service isn't working as I believe I didn't update a credit card change. I cant request a ticket. How do I update my banking info if I cant access my account?
Thanks,
Payment
03-17-2025 08:10 PM
You can purchase a voucher and dial 611 and enter the voucher number to get service running again while you wait for a CS_Agent help you access your account.
Vouchers can be purchased from 7-11, Canadian Tire gas stations, London Drugs, Canadian Superstore, Shell, Shoppers Drugmart, Safeway, Staples
03-17-2025 07:36 PM
hi @eldie is that a problem with the 2FA code? try click Didn't Receive Code and then choose to get the code via email
if you forgot password, try click Reset Password in the login page
if really cannot reset or cannot get the codez PM support agent can help. you can submit by direct message:
03-17-2025 06:38 PM
You should be able to message a customer service agent with the following link. Good luck.
