11-25-2024 03:20 PM - last edited on 11-25-2024 05:15 PM by computergeek541
I'm traveling outside North America and will need service with service provider in that particular country. How to do unlocked my phone with Public Mobile?
11-27-2024 10:22 AM
Greatly appreciate your feedback 😃
11-25-2024 05:36 PM - edited 11-25-2024 05:37 PM
@Jacko123 You can check in Settings. For example in an iPhone go to Settings - General - About - Carrier Lock. It should say "no sim restrictions" meaning it is unlocked. My iPhone with PM certainly isn't locked. You can try a similar path for Android or let us know what phone you have and someone may know how to find it in Settings.
11-25-2024 04:01 PM
My previous service provider was PM and still is and purchased my phone unlocked. Knowing this, a community member responded, PM does not lock our phones. That said, are you able to also agree that this is correct?
11-25-2024 03:57 PM
My previous service provider was PM and still is and purchase my phone unlocked at that time. Knowing this, a community member responded that PM does not lock our phone and that I should be good to switch out the SIM without an issue in Thailand. That said, can you confirm that this is correct?
11-25-2024 03:44 PM
PM does not lock phone. And try a non Telus, non Koodo sim card on it. If it works, then the phone is not locked
11-25-2024 03:43 PM - edited 11-25-2024 03:43 PM
@Jacko123 A carrier would never lock a phone they didn't sell you directly, and even then they haven't legally been able to do that in Canada since 2017. You're good to use your phone with a Thai carrier.
11-25-2024 03:41 PM
My previous service provider was PM and still is and my new phone came unlocked. I just needed to know if PM locked.my phone before I travel and get a new SIM
11-25-2024 03:40 PM
Any phone sold in Canada since 2017 must be sim unlocked per federal legislation. Also, as noted Public Mobile does not sell phones, so even if it was locked you wouldn't be able to get help for that here (you'd need to go back to where you bought it).
11-25-2024 03:37 PM
My previous service provider was PM and still is. I needed to know if PM has locked my phone before I travel to Thailand.
11-25-2024 03:31 PM
Thank u 4 the tips
11-25-2024 03:28 PM
you sure your phone was locked? try different sim cards from different carriers. If it works on multiple brands , then the phone is already unlocked
11-25-2024 03:28 PM
Thank u so much 4 responding quickly 🙏
11-25-2024 03:27 PM
If you believe your phone is Locked, you have to contact company which sold you that phone or previous service provider.
One way to confirm if your phone is locked is to insert SIM from other(s) providers. Or you can go to any mobile store (Bell, Rogers, etc.) and kindly ask to verify if your phone is locked or not.
11-25-2024 03:27 PM
hi @Jacko123 PM does not sell phones anymore and when they sold phones back then, they were all unlocked
if you got your phone elsewhere, you have to as the carrier you got the phone from to unlock
11-25-2024 03:24 PM - edited 11-25-2024 03:26 PM
PM doesn't lock cellphones...you should be good to go anywhere.
added...just take out PM sim and install foreign sim when you get there.
