03-15-2025 04:53 PM
I have a moto g stylus (2021) phone and I am the USA currently.. I have the Can USA Mexico plan but I cannot make a call anywhere... as soon as I dial the number the call ends
03-15-2025 06:15 PM
@Teckie231 wrote:I was able to fix it by changing a setting & using 3G instead of LTE
it's interesting that your calling now works. We've been told by PM that the 3g network in USA has been retired and we all need a VoLTE cellphone. Can you please confirm some info for us...where are you in USA ? Are your calls routing through AT&T, T-Mobile or someone else ? So...you can send and receive calls...correct ?
03-15-2025 05:25 PM
Good point. Thanks
03-15-2025 05:23 PM
@Techfish wrote:Is your roaming off? You would need to enable it.
Most recent phones do not specifically have a roaming setting. While a customer could have a specifcally selected, the option is not usually labelled as a roaming option. Most phone do have a data romaing setting, but that setting has no effect on customer's ability to make or receive phone calls (which is what was being asked about).
03-15-2025 05:09 PM
03-15-2025 05:03 PM - edited 03-15-2025 05:03 PM
03-15-2025 04:57 PM - edited 03-15-2025 05:07 PM
You will need to enable Roaming and enable VoLTE. Then manually connect to AT&T or T-Mobile or Verizon.
If your Moto Stylus is not 5G then connect to T-Mobile on 2G because it looks like it is not on the whitelist of phones that will work on VoLTE.
03-15-2025 04:55 PM
Did you connect to USA PM partners? You might need to connect manually, reboot and try again.
