Transfer from tules
TTwang
Please help me, I just transfer from telus, and I installed ur eSIM and delet the telus’s esim. But ur eSIM doesn’t work. For login ur app, it ask for the code send to my number, which dosnt work
2 REPLIES 2
TTwang
thx, i just send a mail through ur link. 🙂
hi @TTwang  make sure your PM eSIM is active ( or Turn on this line is enabled on iPhone).  Click Reset Network Settings on the phone and try calling
if you still unable to make it work, then you will need support agent to help, you can  submit by direct message:
