Unable to make or receive calls from home
skertchlym
Unable to make or receive calls while at home. *611 does not work either. On day three.
11 REPLIES 11
@Alexandf wrote:
@skertchlym
open ticket with PM support and ask them to check account.
 At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
The issed has already been fixed.
Alexandf
@skertchlym
@skertchlym wrote:
Lynn valley
Have just been able to call my wife's phone while home. First time in 3 days. So I am suspecting it is a cell tower problem.
self solution removed
Clipped from Istheservicedowncanada.com...
Updated 2 minutes ago: The latest reports from users having issues in North Vancouver come from postal codes V7L, V7G and V7J.
skertchlym
Thank you.
HI @skertchlym   that is good it works again
next time, try to reseat your sim card with a reboot
skertchlym
Lynn valley
What general area are you in ? There could be an issue with that particular cell tower reception.
skertchlym
Making call away from home works fine. My wife has the same issue.
hairbag1
Does calling work when you're away from home ? If not...maybe your account is suspended. Or...maybe you've used up your 100 minutes of outgoing calls, if you have the $15 plan.
In either case...log in to your account...but make sure to use incognito mode to get the most up-to-date info on your account.
edit'd...you should be able to call 611 though...so try rebooting phone as suggested above.
Also...make sure battery is charged up !
JK8
@skertchlym
Can you try reinstalling SIM card? Reset network settings? Try sim in another unlocked phone?
