03-26-2025 07:50 PM
Hello, my data connection stopped working suddenly. I didn't make any changes to the account, nor subscription. Data was working perfectly for months. I've reset network settings, unregistered/reregistered on network, changed between 4g/5g, restarted the phone multiple times, still the same thing. I have cell service and can make calls and send/receive SMS, but no data at all.
Can I get any help with this?
Using an esim on s23 Ultra.
04-07-2025 06:57 PM
Thanks all for the help, it was much sillier than that, as it seems my Mobile Data option in the Samsung tray flipped off shortly after an update. I confirmed it happened to someone else with the same model.
03-26-2025 09:14 PM
check if your phone has a data limit enable. If it is, better to disable "Set Data Limit" or at least update "Start billing cycle on" date to match your current cycle start date (PM has a 30 days cycle and your phone uses monthly cycle, that date will be out of sync all the time)
03-26-2025 09:03 PM
If you did not run out of data, it is possible you have a network issue and require the assistance of a customer agent. You can send a private message to a customer agent using the following link. You should include your account number and the last four digits of your credit card to verify your identity in your private message.
03-26-2025 08:37 PM - edited 03-26-2025 08:38 PM
Login to your account on the PM app or website and under Usage Breakdown>View Usage History. You can filter only data.
03-26-2025 08:04 PM
Did you run out of data, use up your quota? What does the usage say in your account?
