USA 15 days talk and text
11-20-2024 04:21 PM
I have 15 USA talk and text . Been here 8 days. I still can’t make voice call. Call ends.
Add-Ons
11-20-2024 04:36 PM
@sprow It.
Could be totally unrelated but I've seen several several messages here in Canada where people have indicated they cannot even make local calls.
So for you in the USA, could be due to that even though no confirmation or announcement has been made.
Good luck.
11-20-2024 04:34 PM
You can manually connect to AT&T if T-Mobile didn’t work.
11-20-2024 04:26 PM
@sprow If you phone is not on the PM voLTE whitelist making phone calls work be difficult. And you only option would be to try phone set to 2G/3G and connect to T mobile for voice calls
VoLTE white list
https://www.publicmobile.ca/en/on/get-help/articles/volte
11-20-2024 04:25 PM
Hi @sprow
data works and just not voice?
try changing your network mode to 2G and change the network connection to automatic and choose T-Mobile and test calls again
if same, it is a problem that your phone cannot use VOLTE and also not able to use the 2G network for voice
only workaround is to use VoIp app like TextNow to make and receive calls using the app
11-20-2024 04:25 PM
what phone you have? probably VoLTE problem
did you try using 2G network on T-Mobile?
11-20-2024 04:24 PM - edited 11-20-2024 04:25 PM
@sprow the issue is most likely that your phone does not or is not supported on Public Mobile whitelist for VoLTE devices. Best you can do is try manually connecting to T-Mobile as they are the only cell company in the US that still has 2G Support. If manually changing to T-Mobile alone does not resolve your issue you will need to change the network speed to 2G as well. If you cannot connect to T-Mobile in your area you will unfortunately be out of luck but you can still text and use data so you can use WhatsApp or other apps that are similar
* adding the VoLTE whitelist if you want to look up your device:
Scroll towards the bottom for a list of VoLTE-roaming enabled devices:
