01-31-2025 02:04 PM
Hello,
I purchased my subscription 05/18/2018. It cost $45/month for Canadian unlimited text/talk and 2.5GB (or maybe 10GB? - it's not clear).
My husband's subscription has more data and unlimited tex/talk and only cost $33/month.
What do I need to do to get a better deal for my plan to match my husbands?
Thanks
01-31-2025 05:38 PM
You need to watch for better offers. You are in control of your own account and things are often changing.
01-31-2025 02:14 PM
@MischaM If you don't see a cheaper plan when logged in to your account then it isn't available to you. You may see a $30 plan that doesn't include roaming, so you could switch to that for now and then select a different (better) plan for next renewal but if you do that and "change now" for the $30 plan you will lose the rest of your current plan with no refund.
Another option if 2GB of data monthly is enough for you and you don't need US/Mexico roaming would be the Telus $100 per year plan which has a special offer on it now if you use the promo code. Talk and text is unlimited for the next year, then you could come back to Public Mobile as a new customer with a new plan. See
01-31-2025 02:11 PM
you might have some cheaper plan like $37 plan
login My Account and check Change Subscription and see what cheaper plans you have there
01-31-2025 02:10 PM - edited 01-31-2025 02:11 PM
You have to go into your account and change your plan as it doesn't get updated automatically. Prices for data have come down dramatically since 2018.
I'm not sure what plans are currently available as it seems they're rolling out new higher priced plans as of today unfortunately.
