01-07-2026 09:09 PM
01-07-2026 09:34 PM
but what phone you have? And you removed the old provider sim card or disable old provider eSIM? Only PM eSIM should be active and set as Primary
if that still does not work, you will have to message PM and ask them to reprovision the sim/account
01-07-2026 09:26 PM
New esim
01-07-2026 09:11 PM
is that a new activation? physical sim or eSIM?
none of voice, text and data work at all?
what phone do you have? can you test the sim card in another phone?
and remember to Reset network settings on the phone. If you have an iPhone, update the Carrier profile
and if you need PM to help, open a ticket. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
01-07-2026 09:11 PM
hi @Toothless1
what phone do you have? did you try Reboot the phone and Reset Network Settings?
