08-05-2026 03:44 PM
I purchased the $50 plan and activated the SIM card and when I go to make ph calls is says I have no minutes but it’s unlimited talk and txt in the $50 plan so what’s up?
08-05-2026 03:48 PM
hi @DSM_81 Reboot it once more time
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
08-05-2026 03:47 PM
I have turned off my phone and still have the same issue
08-05-2026 03:46 PM
hi @DSM_81
it was just a system glitch. Reboot your phone and it will be good
