a week ago
Can I stop subscription of my current plan and resubscribe before 90 days to get same plan. Om currently on 18 per month plan but dont see this plan on available options. Is it possible to get same plan if I subscribe after my current expiration and before 90 days to get same number.
I want to use this no as secondary without losing current no. Pls suggest best way.
a week ago
a week ago
Its 1GB with unlimited calls
a week ago - last edited a week ago
@0_o wrote:of what is included in this coveted $18 plan…? 🙂↔️😏
Some customers were offered an $18 plan that includes 1GB of data. I don't find the plan to be very good, but this is going to depend on the usage needs of each customer.
a week ago
a week ago
you have the coveted $18 plan but you want to travel for awhile. Why not just keep paying while you're gone. Not sure how long you're going away for but... lets say 6 mos. That's around $108 + tax to keep your account active, you still amass Points, your number is safe and the $18 plan is yours when you get home. No need to port away / back in... or any other drama.
a week ago
Sorry, no cheaper in-market plan you can change to
If you are leaving Canada for more than 6 months, you might want to port out the line to some VoIP provider. One popular one is Fongo. Then, when you are back, you are move it back to a regular mobile provider
a week ago
Will try thanks. Is there any other way to get cheaper plan to keep the mobile no without any data
when you unsubscribe, you are just disabling Autopay from credit card, but the same $18 plan still tied to your account
So, when you come back before the 90 days, you just need to pay $18 to resume service with the same plan.
