2 hours ago
Hi,
I have bought a Talk-Txt-3GB(15d) US roaming on Aug 2nd at 4pm EST.
We left for US in the evening; everything was fine for the first 2 days, but on Aug 6 both data and voice stopped working - cannot send/receive calls or have internet access.
I have used this package before with no issues.
It's also strange that when check the "Subscription" page, only see "US Roaming-Unlimited Txt(15 day) and "US Roaming-Unlimited Talk(15 day), but nothing about data!
Any ideas?
Thank you!
24m ago - last edited 24m ago
@drg-ott-1 Have you checked that data roaming didn't accidentally get turned off? What phone do you have?
26m ago
@drg-ott-1 it could be a network problem with your area.
Try again in another area. Reboot the phone once more and try again by manually connect with the 2 carriers as well as Verizon
If still fails, login to My Account and confirm if roaming option still showing there
29m ago
Hi,
I tried both AT&T and T-Mobile and I have LTE network mode, but same problem persits.
Related to the first post, I have paid 30 CAD for this add-on. As mentioned, I have used it many times before with no issues.
Still looking for a solution.
Thank you!
an hour ago
@drg-ott-1 How much were you charged for the add on?
2 hours ago
which network you were connected to?
Try to manually connect to both T-Mobile and AT&T , test both and one of them should work
also, make sure your network mode is set to 4G/LTE instead of 5G or automatic.
