2 hours ago
I was hooked up with Virgin, changed to PM. I opted for an Esim but my data is not working and I cannot send pictures in texting. Do I need to take out the virgin sim card first? I can call and text but no data seems to be working.
2 hours ago
That worked! Thank you so much! One more thing, do I need to remove the virgin sim if I have a PM Esim?
2 hours ago
Settings -> Connection -> SIM Manager, enable the PM sim
Or if confused, post us a screenshot
2 hours ago
It's a galaxy S22. Can you be more specific with details on where to go to find that setting? Thank you.
2 hours ago
Yes, it was a comma 🙂
Fixed
2 hours ago
Thank you! Is that a typo Cellularz?
2 hours ago - last edited 2 hours ago
Yes , you need to take out Virgin sim.
And insert PM sim if your PM sim physical
If eSIM, check sim manager or Settings -> Cellular, enable PM sim and change the label to Primary
Reboot phone and Reset Network Settings. Test both incoming and outgoing calls, check data
