07-15-2026 01:13 PM
@Add-ons @plans
I purchased the Unlimited U.S. Talk, Text and 5GB Data Bundle (15 days) for my upcoming trip to the USA.
However, when I check my Public Mobile account, it shows Incompatible data add-on" under the U.S. Roaming – 5GB Data section.
I'm traveling to the USA tomorrow, so I'm a bit concerned. Could you please check whether my roaming add-on has been activated correctly and let me know if I need to do anything before I leave?
Thank you for your assistance
07-15-2026 05:53 PM
Remember to enable Roaming on your phone when you are in the USA. Enable Network Selection to Automatic and your phone will connect to AT&T, T-Mobile or Verizon.
07-15-2026 01:35 PM
@bobyk wrote:
i purchased this add on
Looks like you did it right. I suspect that message was an error or glitch message. When you get to the border you'll get a Welcome to USA message with a nag to buy a talk add-on....just ignore it as you already have it.
If you wish you can message Customer Support to confirm it was added to your acct properly..
07-15-2026 01:25 PM
07-15-2026 01:24 PM
it might just be a glitch in the system. I've used the 15 Day US Roaming add-ons while in US without problems. Make sure you have a newer cellphone that is on the Public Mobile whitelist as not all cells will work in US for talk.
Here's some reading with a device checker at the end of the article. Regardless...text and data will still work.
07-15-2026 01:21 PM
my regular plan is only for canada
07-15-2026 01:16 PM
what's the details of your regular plan ? Do you subscribe to a Canada / US plan already ?
