Data and Texting Does Not Work
Nancyleopard
Hi Public Moble,
My data and texting does not work. Can you fix them please?
Warm regards,
Nancy
1 REPLY 1
@Nancyleopard
make sure your mobile data is turned on, and make sure you don't have any Mobile Data limit enabled
check if any major outage in your area:
https://www.telus.com/outages
and proceed with a Reset network settings after a device reboot
if issues persists, ask PM to check and reprovision your account.  Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Ticket", click "Contact Us"  then choose a topic, click "Login", finally click "Click here to submit a ticket ↗
    (if unable to receive 2FA via SMS when login, click "Didn't Receive code" or "Resend Code"
                then choose "
Send email" or "Send Voice Message" to get 2FA via email or voicemail)
