3 hours ago
I have the $35 Can/Us talk and text plan that tells me I have used all of my US minutes when I try to call Puerto Rico when I have not used any US minutes. My account is paid up to date. My grand daughter also has the same problem. We both purchased this plan to travel this summer.
2 hours ago
@LucyJean There were two $34 50GB plans a little while back, one was Canada-US and one was Canada only. Have you verified in your account that you got the right one?
2 hours ago
@hairbag1 wrote:
@will13am wrote:
@hairbag1 wrote:
@TheSterlinger wrote:@LucyJean
Puerto Rico is not the United States of America, so you will need the Add-On "300 International Long Distance Minutes" it is $15.00 you can purchase on the add-ons page.
https://myaccount.publicmobile.ca/en/account/manage/shop/addonsIncorrect...customer is able to consider PR as part of US calling.
Are you sure about that? The 300 minute international long distance add-on refers to Puerto Rico as being included in the list of countries covered by that add-on.
Well, PR is part of US so I don't see why it isn't included....along with US Virgin Islands also.
It is kind of confusing when the international roaming add-on mentions Puerto Rico. Customers could buy US minutes for Puerto Rico and save some money. Anyway, I tried calling a Puerto Rico number and it worked on US minutes. However, no such luck calling US Virgin Islands (area code 340).
3 hours ago
3 hours ago
Yes, I realized.
3 hours ago
3 hours ago
3 hours ago - last edited 3 hours ago
It's apart of the plan, try restarting and calling again. If the issue persists contact CS agent via this link. https://myaccount.publicmobile.ca/en/account/manage/shop/addons
3 hours ago
HI @LucyJean
it should be part of the roaming and you should be able to call. Did you can by dialing 011-1-number?
Reboot phone and try again. If that does not work, ask support agent to clarify
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
