12-07-2024 12:59 PM
I'm in Arizona with family. Three of us have public mobile accounts. One is a brand new 100 GB us/can plan, another was an old account upgraded to the 30 GB us/can plan, and mine is a cheap plan with a 15 day talk/data add on. We're working with one iPhone and 2 androids.
We had a lot of trouble our first 3 days here, but eventually got phone, data, MMS working on all devices. Then, night before last, we stopped being able to send MMS or make and receive phone calls. We hadn't made any changes to our devices or to the location where we've been staying.
I've gone through all the trouble shooting device and have run out of ideas.
I'm going home before my 15 day plan expiries and really need to have access to calling features. My mother will stay until the end of the month and I don't want to leave her without access to the phone.
I have submitted a support ticket but wonder if the community may have some other ideas as well... As I'd like to get back to the pool to enjoy the last few days of my trip.
a month ago
@LoraleeH Our devices are all VoLTE enabled.
Having a VoLTE capable phone, and the VoLTE toggled on, doesn't make the phone work with VoLTE if the carrier hasn't enabled it on that particular device. I had that experience myself with another carrier.
a month ago - last edited a month ago
@LoraleeH No, your phone's are not on Public Mobile's VoLTE whitelist (Samsung Galaxy 10+,
Umidigi A5Pro, iPhone 6S).
a month ago
12-07-2024 02:44 PM
without a volte enabled cellphone, your calls won't complete while in US. If you find data is working as expected...you could both download WhatsApp and talk / text each other easily at no additional cost. She and you can use either local wifi or your PM data to use WhatsApp. Anyone else in your contact list that also has Whatsapp can be contacted also.
12-07-2024 01:55 PM
We're trying to conserve data usage, but I'll still make sure those options are available. Thanks
12-07-2024 01:47 PM - edited 12-07-2024 01:49 PM
@LoraleeH, the same devices may have worked fine in Europe with other carriers but unfortunately they need to be on Public Mobile's whitelist, which means that in the backend, Public Mobile has not enabled this feature not non-whitelisted devices. My wife also has a Samsung Galaxy s10+ and experienced this first hand while in Florida. She ended up using WhatsApp over data and had no issues, and in fact preferred using it to make video calls. There are likely other apps that can also be used like Facebook's Messenger
12-07-2024 01:46 PM
I did yesterday, but I'll give it. Atry now again. It's worth a try. Thanks
12-07-2024 01:45 PM
@LoraleeH None of those phones are on the VoLTE list at Public Mobile. The fact that they work with other carriers VoLTE doesn't mean they'll work here. I'm surprised you had calls working for the first part of your trip. I wonder if you had connected to a T-Mobile 2G connection temporarily.
Still doesn't make sense about SMS though 🤔
12-07-2024 01:43 PM
I've checked the volte list, yes. They're not on it (they're old), but they do work on volte. We've used them all throughout Europe this year and they did work fine for most of the past week.
12-07-2024 01:37 PM
@LoraleeH, you might have tried this already but just in case you did not, have you tried powering off the device and waiting a few minutes and then powering back up? Or, turning phones to airplane mode and then turning airplane mode off?
12-07-2024 01:28 PM
Talk issues are often related to the device not being VoLTE compatible, but SMS not working seems odd (especially because data is working). What model phones are we working with here? And do you by chance have multiple sims setup on the phone?
12-07-2024 01:27 PM
12-07-2024 01:21 PM
Yes, we're set to 4G and tried 2G (everything stopped with 2 G, but it was worth a try)
12-07-2024 01:21 PM
hi @LoraleeH talk is always a problem for mom VoLTE whitelisted phone
I suggest you to use WhatsApp or FaceTime for calls , or if you use more traditional calling, download TextNow and use the app to make and receive calls and text on the number the app assigned you
12-07-2024 01:18 PM
Yes, data worked on all three but text and talk didn't, soo we switched to T-Mobile and everything was going swimmingly, until it wasn't. 😞
12-07-2024 01:16 PM
Yes, roaming is on and I've tried Verizon and AT&T. Neither worked during the first couple of days either, but the setup with T-Mobile, as recommended by the community, worked great.
12-07-2024 01:12 PM
hi @LoraleeH
but mobile data work on all 3 without problem?
unless you have trouble with voice, you should also try AT&T and Verizon and not just ticket with T-Mobile
12-07-2024 01:07 PM
@LoraleeH Best for you to set phones to 4G/ LTE not 5G and try connecting to not just T mobile but AT&T and or Verizon , also if you phones are not in the PM
voLTE white list making calls can be difficult and in that case you need to reply on phone set 2G/3G and connect to T mobile for voice . Only other option other then that would be to download text now app or what’s app for voice
VoLTE white list
12-07-2024 01:05 PM - edited 12-07-2024 01:07 PM
@LoraleeH What models of phones do you have, e.g. iPhone 8 or more recent? Have you tried the other roaming partners, AT&T and Verizon? You have data roaming turned on?
