US add-on not working
Ang2
 I purchased a US add-on and was charged but it’s not working on my phone. I had previously purchased the same add-on and it worked fine.
@Ang2 wrote:
Thank you. I waited until it expired and more than 24 hours.
@Ang2
So, it is more than 24 hours since the first roaming set expired.
 if you try login My Account again using Incognito mode, you should see that charge sitting  as Available Fund.
As long as you see the charge in Available Fund,  you can try to buy again and it should work ,
If you don't see the charge in Available fund or if you still cannot buy, open ticket with PM support
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
Ang2
hairbag1
@Ang2
the rule of thumb is to wait until old US Roaming add-on has expired...then wait another 24 hours before re-buying the same add-on.
Alternative is to ask CSA to assist.
dust2dust
Do you still see the amount in your balance? Do you see the previous showing as 1/15 or 0/15?
Re-buying the same add-on has always been a problem. You could buy the other bundle. You could wait until you don't see the prior add-on. Or you can ask support to re-buy it for you.
DDM69
Are you able to connect to a US network?
What add on did you purchase?
