02-20-2023 08:05 PM
I purchased a $30 add-on for 15 days of talk and text and 3GB of data in the US. It does not appear to be working in Nevada.
I've tried the following:
All have not yielded any results. I noted one post that suggests asking a moderator. However, I'm not sure how to do this after sifting through the forum. If anyone could provide some guidance, I would greatly appreciate your help.
03-03-2023 10:42 PM
I had the same issues. I found that I had to switch my voice and data options to LTE. Settings - cellular - cellular data options - voice and data.
02-22-2023 08:52 PM
Have you checked out the cell mapper link? Very cool map. From what I can tell there is a lot of towers on the strip that carry 2G and 4G. What kind of phone do you have? Maybe that's the problem? Is it compatible? Or maybe your signal is being blocked by other large hotels or something?
02-21-2023 03:35 PM
@Marcus2 Just as a FYI, only the roaming options will be available for you to use while in the US.
The 500 LD international minutes can only be used when you are in Canada to the countries mentioned usually, although some customers have had success calling to countries not on any official list at PM.
02-21-2023 03:33 PM - edited 02-21-2023 03:37 PM
@Marcus2 look like Vegas does not have stable connections even with 4G
https://productioncommunity.publicmobile.ca/t5/Get-Support/Data-in-the-USA/m-p/947201
try to buy local data sim for now
When you are back in Canada, open ticket with PM to request refund
02-21-2023 03:31 PM
@Marcus2 Unfortunately roaming in the US is hit or miss rose with voice , this is due to the fact US is getting rid of 3G service so makes for a spotty experience on some cases .. so customers have to rely on the 2G services of T mobile. For voice text and data should be fine when 4G /LTE is available through T mobile
02-21-2023 03:25 PM
Hi All,
Just wanted to thank you for your prompt responses. On forums, I usually assume I won't get an answer for a few days.
02-21-2023 09:21 AM - edited 02-21-2023 09:21 AM
Are you in an urban area or rural? Read this post by @darlicious for more info on US roaming. There isn't a lot of coverage out in the desert only in the cities.
02-20-2023 10:33 PM
Is this your first or second addon you purchased?
If this is the 2nd time buying this after your first one expired, the first one may not be fully expired yet. Plus you need to wait another 12-24 hours after it expires to buy the same addong (silly, I know). OR, buy a different bucket of roaming addon...
If you want the 2nd $30 to work, submit a ticket to CSA to have them activate it for you.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
02-20-2023 09:27 PM
here's where you'll see any add-ons including the 15 Day you bought. Log in to your account / Plan and Add-ons...look to the right side of page. Do you see mention of the add-on ? If not...it wasn't added successfully.
02-20-2023 08:37 PM
As far as customers experience, Nevanda might not have great 2G network for voice. But you can still try to work on your LTE/4G network first
Make sure your Preferred network type or Network mode is set to Automatic, or anyone settings that include LTE or 4G
Try to see if your phone sees T-Mobile network and try to manually connect
Try in different part of the city and hope it is better
You can check the T-Mobile LTE coverage (for data) or GSM coverage (for voice) here and see if your city has T-Mobile coverage:
02-20-2023 08:06 PM
@Marcus2 Make sure your manually connected to t mobile and reboot phone
