iPhone Data not working!
vincejeeva
Hi there,
Public Mobile chat is currently down for me. My data is refusing to work. I restarted my phone multiple times, airplane mode off and on, double checked my APN and it’s still totally dead yet it shows I have 5G. I have 18GB used out of 75 as well.
I have an iPhone 16 if that helps. I am also in New Jersey, USA, travelling at the moment and my phone always works here tested over two years in the same area. Please advise, thank you!
2 REPLIES 2
Meow
Chat is dumb AI so not a big deal if it is off-line...
Since you are not in a native country all kind of issues could occur so no help here...
@vincejeeva
With data issue in US, It could be a problem with roaming on one of the 3 US roaming partner,  AT&T.
But first, make sure you have turned on Roaming Data on in the phone
Next, change the Network Connection from Automatic to Manual and select and test each of these networks:  T-Mobile/Verizon/AT&T, and see which one you can connect and work best
If you able to connect to one of these and work, please report back and let us know which working network is that
