US 1000 minutes not working
Kristina34
I am in Canada and my spouse is in the USA with a US phone number.   I had USA long distance as a promo and when the 400 US minutes ran out I paid the $15 for 1000 US long distance minutes.  Since Feb 22, 2023 I have used 30 minutes of the 1000.  But today I cannot connect to call my spouse.  My add on is there with 970 minutes remaining.  My account is paid and active.  I have tried power cycling my phone and submitted a ticket,  but I need this to work.....
18 REPLIES 18
Kristina34
It was current information for the plan and usage .  Still works intermittently and is frustrating
@Kristina34  you’re correct , so strange keep us posted on what support says the issues is … fingers crossed they fix it quickly for you
Kristina34
lol.  I mentioned it to him.    hopefully that isn't it.  he can call me and we can text message without issue.
Kristina34
definitely have to minutes available.
Hi @Kristina34
it is weird other number works and just not that one
to keep the communication before the issue is fixed, ask your spouse to get a VoiP app, like TextNow. You can him from your phone and the app will ring on his phone.  It is free
lol Maybe he put you on call block. 🙂 Or silent ring.
Kristina34
sorry hit the wrong button.  the issue is unresolved and in the hands of the CS agent that reached out to me through the ticket.
I guess we will have to use Whatsapp in the mean time.
Kristina34
100%   I troubleshoot it before submitting my comment/question and submitting my ticket 😕
Kristina34
The add on was applied to my account on Feb 20.  It worked fine until this am and we can text no issue.  He can call me no issue.
I have called a different North Carolina phone number and was able to connect no issue.
I have rebooted my phone several times today and still not able to call him.
I am waiting for a reply from a CS agent.
just frustrating as he is halfway through a 13 hour drive and I cannot connect to him.
Hi @Kristina34
if you rebooted phone once and same, open ticket with CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Kristina34
I bought the add on on Feb 20, when my 400 US minutes were used up.  My hubby arrived from North Carolina on Feb 22, so we were in the same household for a few days.  He is on his way back today, Feb 26, and I was calling him to see how the trip back to NC was going and couldn't get through.  He is able to call me and we can text no issue.
Kristina34
Hi, Thanks.  I can confirm that I have 968 minutes left of my 1000 US minutes add on, as I was able to call my spouse without issue up until today.  He can call me, and we can text each other.
HI @Kristina34
And check your My Account again.  Check if the money you thought you used to purchase the addon is in fact sitting as Available Fund.  Maybe you loaded the fund and the money was never used to buy the add-on
dust2dust
What is the significance of Feb 22? Is that when you bought the add-on?
What are the chances you've been talking for over 16 hours?
HI @Kristina34   call from Canada to US  should work
The calling out sometimes has glitch and need to wait a bit.  Try calling another US number (call some random bsuiness number from google search)
Wait 15 mins, reboot and try again
and open ticket with CS agent if that still does not work
First type Contact,
Meow
If you managed to submit a ticket then you just have to wait until agent gets back to you.
Did you power off, wait a bit and then power on your phone or just did reboot?
@Kristina34   you could be checking the cached usage and hence the usage to the long distance was wrong
try login to My Account again using Incognito mode and see how much minutes left
if that still shows you have minutes left, then try to reboot yoru phone once
If nothing works , use a workaround to call your spouse in US.  Download VoIP app TextNow.  You can make calls to US for free.
@Kristina34  Check your add ons
Check add-ons /mins /Data
