why my plan got changed?
zw
I just noticed that I got charged incorrect amount in the last bill and when I checked online, I saw my plan got changed! I didn't do change to my account.
Why was it happened?
2 REPLIES 2
dust2dust
Click all the little spinner refresh icons lowerdown to be sure you're seeing current information.
If you did in fact reply to one of those promo texts then just set up another plan change for your next renewal back to what you had.
JK8
@zw
Did you accidentally say yes to a text message from PM about a plan change?
You can contact an agent.
You will receive a response from an agent faster using the first option below, which is the preferred method.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 6 AM to 10 PM EST
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
