U.S. Talk and Text add-on not working
Henry123
I purchased the add-on, the payment was received by Public Mobile, but it is not working.
13 REPLIES 13
@Henry123 if you are rebuyng the exact same raomin addon you need to wait full 24 hours after the first set expired, or it won't work.
Maybe open ticket with PM support to confirm the purchsse went through successfully or PM can sort it out if there was issue
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
Henry123
I am not sure but I  don't  think I  waited 24hours. Should I  have??
@Henry123 did you wait 24 hours after the first 10 days expired  before re-buy??
Henry123
Sorry, problem still not solved
@Henry123 wrote:
T mobile showing when I go to network. How do I manually select T mobile?
As long as T-Mobile is showing, you're good.
@Henry123
for our reference...when did original add-on expire please ?
Henry123
Henry123
Montreal, in States now, just talk and text. Second 10 day plan, the firsr worked ok
Henry123
Previous one already expired
Meow
According to Public Mobile:
PM will have T-mobile 2G network for US roaming.
Voice and SMS text will still work.
Data will work on LTE, but will switch over to 2G to make a call.
However, the quality of service will vary depending on the different coverage areas when roaming in the USA.
dust2dust
Is this a re-buy? Did a previous one recently expire?
@Henry123
which they roaming add-on you got? Talk? Data?
which city and province you are at??
 try reboot the phone once and manually select TMobile.
hairbag1
Make sure to manually select T-Mobile only.
