01-03-2025 06:37 PM
I just subscribed to the 20GB Data within Canada, the US and Mexico at 5G Speed' 5G Speed' up to 250mbps + Unlimited Canada, US and Mexico wide minutes and messaging plus unlimited international text and picture messaging.
Do I still need to buy an addon or can I just cross the lines?
Thanks
05-21-2025 03:15 PM
01-04-2025 09:32 AM
Thank you. An S23 Ultra.
01-03-2025 11:37 PM
No separate roaming add-on needed with that plan. For phone calls to work in the US you'll need a VoLTE device. What phone do you have?
01-03-2025 06:42 PM
Just cross the line with no worries. Enable Roaming on your phone and you should automatically connect to TMobile, AT&T or Verizon. You will probably get a text from PM about US add-ons when you cross but ignore it if you have the Canada US Mexico plan.
