Activation
Madison2008
Activated phone yesterday but not getting any incoming calls or texts
@Madison2008
It sounds like the porting process is not completed. If you ported your old number over to PM, the most important step is to reply to the text with YES with your old SIM in your phone. If this is the case, you need to contact a CS_Agent by Creating a Ticket on SIMon Chatbot bottom of this page or private message on the envelope icon above to restart the porting process again.
But if you picked a new number then just reboot your phone by powering the phone off then back on.
Yummy
Did you port in your number?
What your PM accounts says? Is it active?
@Madison2008 @The card may have not provisioned properly in this case you need a agent
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
Edit have you tried the SIM card in another device to see if it works is it possible it’s the phone itself ?
HALIMACS
@Madison2008
Did you respond "yes" to the port authorization request if you were moving services from another provider to here?
If not, to re-initiate the port, click here: https://urlshortner.tiia.ai/Lc9xk8
Then, replace your old SIM card in your device, reply yes to the text, and then put your Public Mobile SIM card back in and reboot phone.
Madison2008
yes we tried this
@Madison2008 @Did you restart the phone ? Also you can try to take SIM card out and reseat it and make sure it’s in all the way and right side up
