09-04-2022 11:03 AM - edited 09-04-2022 11:05 AM
Hi, is there a way to keep the PM phone DATA working while visiting France and Italy? I'm not so much interested in calls or texts, although it would be good to know.
09-04-2022 06:56 PM - edited 09-04-2022 06:57 PM
Where are you arriving in Europe? If your arrival is in Italy they offer some of the cheapest prepaid plans in the world. Plans have an average cost of €1/1gb with a 30-day plan averaging €20/20gb including European roaming. For more info see here...
https://www.traveltomtom.net/destinations/europe/italy/best-prepaid-italy-sim-card
For France the best deal is about €15/10gb. Find more info here...
https://www.traveltomtom.net/destinations/europe/france/best-prepaid-sim-card-in-france
For more general information about all European SIM cards please see here....
https://www.traveltomtom.net/travel-tips/buying-a-sim-card-in-europe
Here are your options for your public mobile service while traveling...
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels and Stay--Safe!
09-04-2022 04:00 PM
PM not service in Europe.
and used by Wi-Fi and you get a new number from that app and make Call & SMS for free.
or travSIM Prepaid Europe SIM Card, or in airport buy it prepaid europe sim card.
09-04-2022 03:27 PM
There are some pretty cost efficient data/sim options in Europe depending on where you go . A quick search for your country/countries should give you a good starting point.
09-04-2022 11:49 AM
Hi @mountaindew get a local data sim there instead. From a cost prospective, It is always a preferred way even roaming is available (but again, roaming is not a choice here 🙂 )
which countries you are going? many data sim there can work for most European counties
09-04-2022 11:26 AM
Negative.
You'll need a local sim and a European plan in order to have data service whilst in Europe.
09-04-2022 11:24 AM - edited 09-04-2022 11:24 AM
PM does not provide any service in Europe. US has limited access through US add-ons.
Your option is free WiFi or if you need calls voip apps (again, WiFi based).
09-04-2022 11:10 AM
You could however use a voip app that does talk and text and forward calls and use another app to forward texts. Then when on wifi or local data cell service you can talk and text from the voip app getting the calls and texts while you're there.
09-04-2022 11:08 AM
Working = that it can be used, that it will function (ie. work). You've answered: that it will not work there. Thanks.
09-04-2022 11:05 AM
Define "working"? PM services will not work there. You can certainly leave the account active and pay it every 30 days. Or there's a grace period of 90 days of suspension before it dies.
