Thursday - last edited Thursday by computergeek541
What do I do to use phone when traveling? I spent $10.00 for talk & text on my last visit and was unable to use my phone….
Thursday
tell us where you're gonna be traveling and we can suggest some ideas for you as your Public Mobile service will only work in Canada. There's a couple of PM plan options for use while in US and Mexico, but that's it. If you're only going to US for a few days / coupla weeks....PM has 15 Day US Roaming add-on for use while in USA. Other than that, your Public Mobile service is unavailable while traveling abroad.
Thursday
where are you going? US? PM only has roaming addon for US. But if you need voice service in US, it still depends if your phone is VoLTE whitelisted with PM. What phone do you have?
Thursday
@bermudagirl-G86 PM does not work outside of Canada.
If you are going to Mexico, there is a new plan for there only. Other than that, you have to depend on wifi.
Be aware if you change your plan now you might not get it back when you wish to change again. More expensive plans are going to be listed.
@bermudagirl-G86 If your going to the U.S. then you can buy US roaming add on , or get CAN/US /MEX roaming plan and be covered for MEX too , but anywheres else in the world you go your best to get Tavel esim or local pre paid sim in your destination as public mobile won’t work outside US/MEX /CAN
