02-27-2022 02:19 PM
I refer a friend, she wants to transfer her cell# from CMLink to Publie mobile, but CMLInk is not Old service provider list; What can she do to active her new sim
02-27-2022 06:02 PM - edited 02-27-2022 06:11 PM
@Meow wrote:Confirm her current phone number is eligible for porting.
Let her create PM, account, get SIM, activate, etc. Pick any number and confirm everything works as expected (SMS/calls/Internet).
If provider is not on a list (ant there is no 'other' as provider) let her contact agent to help her out.
Send a private message to the CSA by clicking https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
When porting from within the customer's Self Serve account, the customer will not be asked who the old carrier is. Before contacting a Public Mobile CSA, I would first suggest that the customer try to perform the porting from the Self Serve website by using the instructions provided by softech.
02-27-2022 05:57 PM
Others have noted that CMLink utilizes Telus network so when your friend activate the SIM. Remember to keep the CMLink in the phone and wait for a text confirming she is porting her old number over to PM. Reply to the text with YES within 90 minutes of receiving the text.
02-27-2022 02:55 PM
I believe in this case if CM Link is under license by telus you can choose telus when porting but after activation with a temp number thru self serve.
02-27-2022 02:32 PM - edited 02-27-2022 02:33 PM
@xiaogegeying I think CMLink has been using Telus network, so, you should be able to port into PM without issue
"Who is CMLink?
In this Agreement, "CMLink" refers to a trademark being used by China Mobile International (Canada) Limited (“CMI”) and TELUS Communications Inc. (“TELUS”) CMLink is a trade-mark of CMI, and is used by TELUS under license."
https://www.cmlink.com/ca/en/legal/product-terms-and-conditions.pdf
02-27-2022 02:30 PM
02-27-2022 02:23 PM
Ask your friend to activate with temporary PM number first. Then she can contact customer service agent to port her number over afterwards.
Check this website to make sure that her number is going to be able to port over:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
(Koodo site, but Koodo and PM are part of Telus)
02-27-2022 02:22 PM - edited 02-27-2022 02:26 PM
Yes, the list does not cover all wireless providers
First, come to this site (https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal )and make sure your phone is eligible to transfer into PM , this is a safe check
If all good, I suggest you to activate first with a temp. number. Once activated and work without issue, you can re-request porting from My Account. If any issue with the request there, you can submit a ticket for PM to process it manually
[update 2:25pm: forgot to post the link for port eligibility, added back. LoL]
