07-23-2019 07:55 AM - edited 01-05-2022 06:03 AM
It's not the first time that it takes one or two days for my plan to reactivate, although my partner never has the same issue with her plan. I need this to be resolved, or I'll have to switch to another company. Public Mobile can't possibly expect their customers to pay for days when their plan doesn't work.
On my account it says that it's active, but after restarting the phone a few times the last days, data and calls are still off.
What should I do? Could it be that my SIM is damaged and I need to order a new one?
Thank you!
07-23-2019 08:38 AM
Yes, the $1 payment would be via credit card or a VisaDebit, but you're paying with a voucher normally, you could get a small amount ($5 or $10) and use that, the value should all go to Available Balance, as you've topped up already. So you're just putting funds in, not actually using them until next renewal.
Talk is part of your plan, right? Which plan are you on? You didn't mistakenly change to a data-only or a no-talk plan by mistake?
07-23-2019 08:35 AM
I believe you can make a payment anyway you like. But if you have a working credit card on file that's the best. If you do it by voucher you're likely looking at more money than a dollar.
It's in self service under payment. It has worked before.
07-23-2019 08:34 AM
When I try to make a phone call, I get the info that long distance calls aren't covered by my plan.
07-23-2019 08:23 AM
@stonechucker you're right, there's nothing wrong with the voucher itself.
I tried suspending the service and reactivate it like you said, but it didn't work.
When you write top up $1, I'm not sure how you mean. Is that something I have to do with a credit card?
Thanks a lot for the help!
07-23-2019 08:09 AM
@Triguy wrote:There has been an issue with vouchers from Shoppers Dug Mart.
Contact a moderator.
Moderator can be reached at
This isn't a voucher issue - the plan has been topped up, and shows status as active.
@franskarlsson, sign in to the My Account site, go to the Plans & Addons tab, then subtab Lost/Stolen Phone. Press to 'suspend status', and sign out of My Account.
Wait 5-10 minutes, sign back in, proceed to same tabs, and press reactivate.
While waiting, power off, and restart your device.
Another option to try if that fails, top up $1 as a manual one-time payment - this has also jumpstarted the reactivation for some.
07-23-2019 08:05 AM
@Triguy the voucher was accepted and the account is active
@franskarlsson try the lost stolen trick or 1$ trick
If these fail ask mods to invesrigate
07-23-2019 07:58 AM
