12-11-2024 03:52 PM
I understand that it depends on the user what they call the best but generally what is the best plan in terms of $$ Public Mobile has.
I ll start with my 2 cents.
Anything over 5GB and unlimited calling is considered good for under $20 for me personally.
12-21-2024 09:29 AM - edited 12-21-2024 09:31 AM
@Rajaji @$35 for 75gb is best right now and as before this is also in comparison to other provider's offer.
12-11-2024 04:11 PM - edited 12-11-2024 04:13 PM
@Rajaji No it’s only for news activations in Quebec, but if your on the $15 plan now check your account there should be 1GB $19 or 6GB $23 plan to change to . Just be sure to use the change on next renewal option and not immediately or you lose money on your current cycle and no pro rating for unused time . Also note if you do switch you won’t be able to bet the $15 plan back again as public mobile has made it harder to down grade plan price . They just want users upgrading plan price
12-11-2024 04:08 PM
$35 is too much.
Koodo had $30 for 60gb data and unlimited calling.
Is there any chance of changing my current $15 250mb data and 100 minutes outgoing and unlimited incoming calls to this unlimited calling and 250mb data for same $15?
12-11-2024 04:03 PM - edited 12-11-2024 04:03 PM
@Rajaji $20 for 5GB or more with Can-US-Mex would be killer.
12-11-2024 03:55 PM
@Rajaji All plans currently offered have unlimited calling with the exception of Quebec only with the .$15 plan . But I think the 50GB CAN/US /MEX plan for $35 is good value plan also and very popular
