11-24-2024 04:04 PM
Got a text saying that I have used 75% of the data included in my service. I have added 3GB on Nov 1, my phone shows that I have used only 1.14 GB and my public mobile online account says that: I have 3GB of data, I have 1.96GB left and I have 7/31 days left.
11-24-2024 05:21 PM
Public mobile reports data usage once a day usually early in the morning for most customers. See what the customer service agent tells you, but I have a feeling that you have used up 75% of your data, but it has not updated in your usage history yet.
11-24-2024 04:37 PM
@Diana60 In the post you excepted the solution . You see the down arrow by time stamp ? Tap it and edit it if it’s not the solution
11-24-2024 04:35 PM
I didn't mean this was the solution. I was just able to finally message the CS_Agent
I still don't know what will happen with my data. If it gets cut by text I will let you all know, but i will also find another provider.
11-24-2024 04:26 PM
Hi @Diana60 try using another browser. Type the content and do not paste
11-24-2024 04:24 PM
It doesn't work, just doesn't' accept my text
11-24-2024 04:23 PM
Hi @Diana60 just copy what you typed, delete all and then right click. to Paste As text and it would work
11-24-2024 04:21 PM
I tried to message CS_agent but it wouldn't send it, b/c of some error:
So what do I do? Iknow it isn't just a glitch, last time I got a text warning, my data was sopped.
11-24-2024 04:15 PM
You can message CS_agent to check
11-24-2024 04:09 PM
@Diana60 Just another public mobile glitch , like many other glitches the system has . I would worry to much about it even though it can be alarming at first . But if you want to confirm with support just message them
submit ticket with support using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
11-24-2024 04:08 PM
hi @Diana60 the text could send wrong sometimes and you can ignore
but when you check yiur usage, if using app, make sure your drag down the force a refresh. Or use Incognito/ private/ secret mode on your browser if you check using the web version . You can also confirm data usage by calling 1-855-4PUBLIC from another phone
