Switching plan and Rewards
Paul7
I am thinking of switching my plan to the $40 4G Speed 15G 30-Day plan. Will this switching change my rewards from the $ based to a points system, which I wish to avoid?
7 REPLIES 7
Meow
Your rewards are tied up with your Account not plan. So you can switch plans every 30 days if you like it and rewards will stay the same - unless YOU switch to points.
saje_ward
You will not lose your rewards, nor will you lose any of the bonuses on your account like the holiday bonus data and calling minutes. You have to expressly opt in to the new rewards plan, it wont happen by accident. Once you switch your plan, even if you chose to switch at renewal, it will show the amount owing on that renewal date with your rewards applied.
I hope that helps!
HALIMACS
Your question is a valid one @Paul7 , especially given the messaging on the plan descriptions.
The first line of each description makes reference to points:
I think Public Mobile should remove that reference as it's caused a lot of customers to believe they may only qualify for the plan change by switching to points.
As others have stated, you can happily remain on the old rewards system and change plans.
DDM69
I had the same concerns.  No worries!  Enjoy the super deal 😁
walker1
@Paul7
No it won't. Don't worry about that.
@Paul7   No worry, changing plan would not affect your rewards system.  You will still stay on the old rewards with plan change.
The new rewards system will only be changed if you opt-in yourself
Enjoy the new plan
Metal1967
@Paul7  You will keep your rewards
