10-29-2022 08:51 AM
I’m in Newfoundland and I have the 4G plan and no matter what I do or where i am I have the on bar if I’m lucky two I’ve been paying for data and only using 1gb if I’m lucky, it’s been going on for months. I’m wasting my money and can’t change anything. Someone please help jjbh0831@icloud.com
10-29-2022 09:26 AM
Did you talk to other people with PM service? Do they have the same issue? How about people using other providers?
10-29-2022 08:58 AM
Can you try resetting your network connections?
Also, try the PM SIM card in another device to see if you get similar coverage.
You can also try switching to 3G just to see how that affects the signal strength.
10-29-2022 08:57 AM - edited 10-29-2022 09:02 AM
Please remove your email for your own protection as this is an open forum. Go back to your post, click the 3 dots and then select Edit Message
you have an iPhone? Make sure your Carrier Profile is up-to-date.
Try to Reset All Network and see if it helps (please note your saved Wifi connection will also be deleted and you have to add them back after)
Also, ask your friends who are now using Telus/Koodo/Bell/Virgin/Lucky and see what experience they have with their Data. People on those providers use the same network antenna
if you need help from PM, please open ticket with them:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
